I am at the range you are aiming for based on my mods and boost but I still need to dyno to get an accurate number I road tuned with about 35+ renditions with ZZP. Borg Werner S252 LSJ with FIC870SPLIT 870cc injectors. I am running 91 fuel at 23-24 psi. Anything above 24 psi will result in knock and duty cycle is upwards of 85%. I wish I would have purchased 1000cc injectors. I went with the Phoenix Performance Stage 3 Ceramic Clutch Kit and its a great feel.I would like it to be a track/street car with manners, with a normal idle, and a normal clutch, so not too crazy. Most builders seem to like the high 300hp range, maybe low 400hp, so that seems like a reasonable goal.
I have been collecting parts for about 3 years... I plan to keep the supercharger, and do twin charging, like Rauq did.
The turbo I have is pretty big, so the supercharger should help it to get spinning.
ZZP Z57 Turbo (Knock off of the Borg Warner 7163 EFR turbo)
Frozenboost Water to Air Intercooler
870 CC Split Spray injectors (Bosch EV-14ES)
ZZP forged pistons and connecting rods
ZZP Stage 2 Camshafts
Supertech Valve Springs - 75#
Davies Craig Water Pump w/ LCD Controller (removing the stock water pump, balance shafts, and their chain & sprockets.)
and a bunch of maintenance items... valves, valve guides, seals, cam chain & guides, etc.
Do you think you would be able to idle the engine if you were to use 1000cc injectors? I would be tempted to add a 5th injector and controller, if you want more fuel. That way you would still have your idle. Good to know about the Cortex boost controller. I still haven't purchased one, as I haven't found one to control twin charged engines. I have read that other twin charged engines just control one stage of boost.I am at the range you are aiming for based on my mods and boost but I still need to dyno to get an accurate number I road tuned with about 35+ renditions with ZZP. Borg Werner S252 LSJ with FIC870SPLIT 870cc injectors. I am running 91 fuel at 23-24 psi. Anything above 24 psi will result in knock and duty cycle is upwards of 85%. I wish I would have purchased 1000cc injectors. I went with the Phoenix Performance Stage 3 Ceramic Clutch Kit and its a great feel.
After spending months with the boost controller its very difficult to dial-in the boost ramp in 1st ideally from the dig 19psi is about my max going into 2nd gear. The Cortex boost controller is awesome highly recommend. Going from the supercharger to turbo is finally at the point where I have reached my personal limit of control comfort.
What concern do you have with single turbo over twin charged? Is it due to boost lag? The S252 has very minimal boost lag its noticable but for half second maybe 1s. Going with A2A cooler saves so much space by removing the intake and going with a SAAB intake. I would think twin charged would be another big challenge with tuning. Again my biggest challenge is not boost lag but controlling the boost going into second those 275s R88R rip out even at low pressure and 19psi. I bet the sound of twincharged is amazing though.Do you think you would be able to idle the engine if you were to use 1000cc injectors? I would be tempted to add a 5th injector and controller, if you want more fuel. That way you would still have your idle. Good to know about the Cortex boost controller. I still haven't purchased one, as I haven't found one to control twin charged engines. I have read that other twin charged engines just control one stage of boost.
Not sure why put this pictures makes me laugh.
Ross just sees his garage, while everyone else sees his Wizard's Tower.Not sure why put this pictures makes me laugh.
Right now boost is at 19psi going into 2nd it probably should be closer to 17-18psi without losing traction. The transmission is setup with open diff the quaife may be my next future upgrade now that traction is an issue. The boost control with wastegate is not an issue its finding the sweet spot . The cortex is programmed for boost by gear and RPM. When shifting into 2nd at 7k RPM the dip is 5-5500K RPM so that number should be also 17-18psi ideally all the way up RPM to 5500k in 2nd.So how low of boost does your car make when going into 2nd gear? I had too little traction with an open differential, but the Quaife has made it much more controllable. Are you running an open diff? Would running a bigger/ported wastegate give your Cortex boost controller more range, and lower power going into 2nd gear?
The S252 is a pretty optimal turbo for our engines. I am playing with twin charging, just to do things differently. In the end it will be more difficult to tune, and weigh more, but there is a small chance it will have best of both a supercharger, and a ZZP Z57 turbo, which has slow response times. I have never made my own boost controller, but I may end up doing that. I have done 30+ microcontroller projects, so this is a possibility.
We can rebuild him. We have the technology. We can make him better than he was. Better, stronger, faster.Sad Max
It is a CNC machine. One day it will cut foam, for a front composite wing, for a goblin.is the wood structure a workbench or something else?
Glad you got a laugh out of it, although that is not the intent of posting it here.Not sure why put this pictures makes me laugh.
Thanks! If I get bored and need something to do, I just walk out to the shop, and something to do will find me.Ross just sees his garage, while everyone else sees his Wizard's Tower.
Oh good, I'm not the only one with umpteen half finished projectsHalf build goblin. Half build CNC. Half cleaned shop. Half finished French cleat system:
The lot of you have got me lusting after having a house again. Or at least a garage and flat cement! I sure hope I get some land bought this spring! Then get some structures built. I just want all my stuff in one county! Traveling full time and building my car isn’t compatible. But it has allowed me to work on other peoples cars!A man's shop/garage is his castle, err, man cave or something like that! It's my happy place too and it makes my wife happy I'm not in the house!
When you coming to west Tennessee? I don’t really need the help but if you happen to swing by I’d be happy to have you. I work by myself so me and the shop cat have good discussionsThe lot of you have got me lusting after having a house again. Or at least a garage and flat cement! I sure hope I get some land bought this spring! Then get some structures built. I just want all my stuff in one county! Traveling full time and building my car isn’t compatible. But it has allowed me to work on other peoples cars!
IF HRPT takes us to Nashville this year we'll be close! But that is presuming I am successful in bringing GOB-BALT to life! You know, life has a way of de-railing things. As I keep telling all who will listen, GOB-BALT will have to run and drive before I can modify it for speed and handling! Just now it's nothing but near scrap steel, plans, hopes and dreams. It would be nice if it works as well as the first Goblin!When you coming to west Tennessee? I don’t really need the help but if you happen to swing by I’d be happy to have you. I work by myself so me and the shop cat have good discussions
