I added the Davies Craig electronic water pump (EWP) controller to the dash. I ran the wires for the EWP off the BCM fuse #6, but the pump isn't installed yet, as I still need to bypass or remove the stock pump and thermostat. Mostly I wanted the controller to run the radiator fan, as the stock PCM doesn't control it anymore. I lost a transistor inside the PCM. The new controller also has a new thermistor installed in the engine coolant.
Tested the oil pump, it seems to be working, now with it automatically turning off and on with the engine.
Also added the seat heaters and car cameras to the same circuit, and the wires run thru the tunnel.
I put it back together today, and took it for a grocery run. Filled up with gas, and found out that the fuel pump isn't sealed at the top of the tank. Darn, I thought I fixed that. I am struggling to get the 5 bolt fuel pump to seal. I wonder if the LNF's 8 bolt pump is better?
Well, 2 steps forward, 1 step back.
