The goblin fan could be wired to run at 3 settings: off, low speed, or high speed. Right now the goblin uses off and high speed.
This would use the AC Pressure 5V sensor which controls the Fan 2 relay and the SER/PAR relay in a Cobalt. (This circuit could be used for other things that might be more important. For example: an oil pressure sensor and an alarm buzzer instead of Fan 2. This circuit value is available on the canbus, so it can be logged by HP Tuners or programmed to show on a canbus gauge.)
You could substitute a resistor for instead of Fan 2, and remove the Cool Fan 2 fuse & relay (so the resistor doesn't turn on without the fan on).
Then add a temperature 0-5V sensor to the engine coolant or engine oil, and wire it to the old cobalt
AC Pressure sensor.
Then my radiator fan 1 would be able to run a low speed or full speed, depending on what the PCM wants. I can use HP Tuners to set the
tables in the PCM to turn on the fan at full speed.
The resistor from the interior fan speed control could be repurposed in place of Cooling Fan 2.
That speed control resistor normally runs in the moving air, to keep it cool.
So mounting it behind the radiator fan should be good. Use the wires from Fan2, and route them to this speed resistor pack.
There are multiple speeds available to the interior fan, so you can pick what speed you want. I think I would use light blue wire (med-high speed) or the tan wire (medium speed). I would have to test the radiator fan, and see how fast it runs, and how hot the resistor gets. Only run the lowest speed (yellow wire) if it doesn't overheat the resistor.
