Sluggonaut
First start on the first try...so relieved.
I was a little anxious to check to see if the throttle was working; otherwise, it ran fine. I did grab the wrong gas tank and put my lawnmower's 87 in the tank instead of the E85 I ran out to get yesterday.
I was going to try to start it last night but when I filled the reservoir with coolant, I noticed a leak at the thermostat housing. The spring clamp was off the edge of the hose and I had a mess to deal with. After failing to get it adjusted and sealed back up, I worked a worm clamp in there and was able to fix it. I just need to remember to pull the spring clamp off the thermostat housing next time I have it apart.
