Bigfoot Goblin
- Desert Sasqwatch Bigfoot Goblin
Anyone with an answer for this one: Paul's Goblin (SS/TC '09) won't fire off when it is cold. Cranking is fine and after about 2 minutes of spinning it over it will start and idle just fine. Turn it off and it fires right over. Anyone think this is temp related? The MAF and both MAPs are installed correctly, no vacuum leaks can be detected.
The other issue is for the short time it has been driven, feels like the timing is pulled way back. There is not a lot boost 3-4 psi.
Need a quick answer if anyone has ideas. Thanks!
