V1 Bajakid1450’s ss 2.4 turbo track goblin build
Bajakid1450
Do you have a model number? It looks like it about twice the size of mine. Mine works ok for speed but everything else is about to small to see easily.
Can you tell it/program it to display specific things, like the air conditioner pressure? I'm not sure what the Chevy PID is for the AC pressure, but if you can give it any PID, then you probably can find the AC one.
EDIT!!!
Wrong link…. Here for $72 shipped with prime??
Car HUD Display, GPS+OBD2 Dual System LCD Gauge Display Instrument, Odometer, Tachometer, Turbine Meter, Water Temperature Meter, Vehicle Fault Diagnosis Machine, ECU Data Abnormal Alarm Function https://www.amazon.com/dp/B09NQCJDWY/ref=cm_sw_r_cp_api_i_527YC9SX2CRNH34K9QRH
Had no idea these existed…. Why even mount the dash cluster, LOL!
According to the Amazon description it doesn't work on pre-2009 cars. Has anyone gotten it to work in their Goblin (or any other pre-2009 car)?
PaulPerger
This may be a CYA situation. It appears it utilizes data from the CAN system through the OBD2 connector. The CAN systems became mandatory for all cars in 2008 with all new cars required to utilize the system beginning in 2009. I am pretty sure the Cobalts used the CAN data system right from the start, so I don't know how applicable that would be to our cars. I am sure most cars were using it before it became mandatory, but there might be a few that weren't, thus the warning.
I have a 2006 donor and I think I am going to buy it and test it out anyway. I do not like the idea of the instrument cluster in the middle of the car...
Bajakid1450
EDIT!!!
Yup that’s it thanks for looking that up, I’ve been sooo busy with work
Bajakid1450
Mine is a 2006 2.4 ss manual and works fine
Bajakid1450
I’ll take a pic of the program and setting sheet when I get home from work later today. I’m not sure all that is programmable but I just installed it yesterday came 2 days after purchasing
