Thanks to everyone for help with this issue.
Part of the fun was that our donor was sitting in a field for 18 months before we bought it. (The price was right). The previous owner said that it was a reliable daily driver until they hit a deer on the freeway, crashed off the road and bent the frame and did other damage. Anyway, we've never seen the engine run,...
I went and bought an engine ground strap and attached it from an empty screw post on the engine (used to hold EVAP or fuel line or something) to the frame ground screw by the fuse box.
I also removed the starter and bench tested it (worked perfectly) and hand turned the engine to make sure it wasn't seized. (It turned just fine)
We attached the O2 sensor (just in case) and put the MAF on (just in case?)
Then we went through all the fuses and they were all fine. We made sure all the ground bolts were tightened and then we reattached the battery.
In the ACC position the carburetor valve responded again and we could hear the fuel pump prime. We crossed our fingers and tried to turn it over.
It coughed and wheezed and ran for a few moments and died. Not bad for the first start in over two years, I think.
So we tried it a few more times and it would run, but really fitfully and it wouldn't idle.
It would appear that failure to ground the engine was the reason it would not turn over and start. Now the goal is to make it run properly.
A few questions:
1. The fan never turned on and I do not think the connection for temperature is attached anywhere. Where does that attach and am I going to destroy the engine without it plugged in? I'd like to hear that fan running.
2. How do I know that the coolant is moving through the system? I don't want to burn things up (checked the oil, the oil level is good. The oil is at least 2+ years old, so I probably ought to change it soon, but I wanted to see the engine run first.)
3. After a few times of running it it wouldn't turn over again. But the odometer reading was saying "engine performance reduced . . . engine immobilized" Anyone heard of that and what does that mean? Gave it a few minutes and then it started again.
4. Where to go from here? The engine starts, just needs some tuning or something and I need to be sure the accessory systems are running.
I figure I will attach and OBD reader and see what it says. I thought I would access the spark plugs and see how they look. Would a dead spark plug cause the engine to run very rough and backfire on occasion?
Anyway, very happy with the success of the engine starting but now trying to figure out how to make it idle properly.
I would love and appreciate some more wisdom from the forum.
Thanks!!!
