V1 Engine pulled from car. Now what?
Even with only 75K on the clock, would recommend replacing the timing chain guide bolt. The factory one will fail and replacement is cheap insurance for engine longevity. :D
It's simply removing the old one and installing the new one.
It's as easy as remove and install if you do it now. Later, when (not if) it breaks it'll be a lot more involved. It took longer to find the right socket than removal and installation of the new part.
That cable should be connected to the handle directly. You don't need the longer cables that connect to the actual brakes as DF supplies new cables.
My kit didn't come with the parking brake cables. I bought replacements for the stock SS cables. Mine were rusty and one was seized.
Blue Man
They have that link to purchase the SS cables in the parts list. Is that link accurate? I followed it and it listed cable I’m assuming it’s the correct one. And then I would just buy two, right?
I purchased that number and it works. Now, how you route it in the kit car is very much open to interpretation. My part number listed in the picture is for a 2006 SS/SC. I don't know if the later models still used the same number. It was very easy to install after the car was running and driving, maybe 30-45 minutes of work. But I already had my handle mounted onto the tunnel cover.
You are correct, 2 cables are needed.
jennam
Sorry. I think you’re right that the cables don’t come in the kit. Now that I think about it, I ordered some from rock auto and I just had them would up in the box with the rest of the parking brake kit.
Apologies for the misdirection.
Blue Man
cutting the car up as I type.
What is this? Do I need it? Everything is getting hauled to the salvage yard in a couple of hours and I'm trying not to haul off things I need.
Thanks!
averageJOEschmo
Sasqwatch, correct me if I'm wrong, but it looks like this is the same part on Amazon:
Dorman 917-954 Timing Chain Guide Bolt Compatible with Select Models (OE FIX) https://a.co/d/8VgkTWt
If the original isn't currently broken, is it really as easy as removing the cap and bolt and then putting the new bolt in? No need to pull the header off to hold the guide in place while installing the new bolt?
Thanks for the heads up, I wasn't aware of this issue.
Joebob
If you have drum brakes, you will need to buy cables for a disk brake car ($20), but the tubes are needed just the same.
