Bigfoot Goblin
Second photo, the open port below the throttle body looks like it is the right size and location for the brake booster hose connection.
Yes, the video shows cutting this junction to the fuel pump and EVAP wiring. As I kept the EVAP system, I ended up drilling out the rivits and keeping the plug as some of the wires change colors to the plugs on the underside of this juntion.View attachment 39775
The disassembly guide told me to cut this wire however in the updated wiring harness video it's completely intact. What's up with that?
In short, I would drill out the rivits and pull the bulkhead connector and keep with the wiring as it makes it easier to splice the lines if you need to later.
If you are not keeping the EVAP system, I thiink the splicing is possible with the underbody length anyway and the keep or not keep is not as important.
Joe
So you don’t make the Mexican starring frog of southern Sri Lanka extinct with those evil hydrocarbons escaping.I looked up and glaced over what the EVAP is all about, I wont have to do emission testing for my goblin. So I guess I can get rid of it? Whats the benefits of keeping it?
that was probably the nastiest part of my build, on top of it the previous owner was a smoker so it smelled bad too.View attachment 39798
Using latex gloves to unravel the tape. Very very sticky. I want to keep heated seats and accessory plugs.
I kept the accesorry plugs and put them in the tunnel in front of the shifter but many put below the instument cluster with a custom bracket. I also kept the seat heaters. Be mindfull that they are more complicated than a simple on off switch in the dash, so you will need the dash switches and make a bracket to hold them. In the end I ended up selling the stock seats and tucked the wires for the dash under the hood and rolled up the seat connectors behind the new seats so I can't say if what I did worked.View attachment 39798
ill look over that thank youOh, and don't forget to extend the Auto shift wires 10-12" It is in the first wiring videos but not in the latest.
Joe
