V1 floor pan kick plate
ole mother
O
Interested in what people did for the floor pan as far as painting. Did people powder coat, spray bomb or other. I am thinking of doing a bed liner product for these pieces any advice.
I painted the kick plate. I did bed liner on the bottom of the floor, after an acetone cleaning of the aluminum. I should have waited longer than a day for it to cure, before mounting it, as it was soft, and easily damaged. A week later is was nice. I wouldn't recommend it on the top thou, as it is messy and gets on your clothes or shoes when it gets scuffed.
R
I've seen people weld in diamond plate and then have it powder coated with the frame. Probably the route I'm gonna go as well. Also seen people lay down skateboard deck tape to provide grip on the floor. Bed Liner will work nicely
Powder coated the floor black and the BCM kick plate to match the chassis. Then made floor mats and put grip tape on the kick plate.
That heavy kick plate? How about an alternative way to make it 'grippy', Racer X cool looking and 30% lighter. And you can do whatever finish you like.:cool: Sorry, couldn't resist. :p
I resisted finishing mine for a long time because I wanted to use dimple dies for grip, but couldn't justify the expense of the tools necessary.
Brett
Powder coat but added skate board grip tape for traction.
I was wondering about powder coat on the thin material. Specifically, flexing during install and if that would cause any issues. Have any thoughts there?
Might do powder coat on my side panels when I get back on it.
Might do powder coat on my side panels and I get back on it.
I had DF do it. It’s a thinner coat with some texture. It seems to flex ok, but I didn’t push it when handling it for install.
Not sure how it would act on the side panels. I wrapped mine.
Goblin Graber
I’m going to get all my sheet metal powder coated to match the chassis for a cohesive interior look. I will wrap the side panels too, but just the outside and probably 1/4” on the inside so the frame tubes hide it. My sides came prebent in a shape really close. Powder coat should have no problem bending the little bit required to put on the sides.
CaptFrank2001
This is how I did it. As we say in the Navy .... "Works fine, fail-safe & drains to the bilge"
Don't look at the crappy tape job. I fixed that.
