ah.b.normal
- ah.b.normal Goblin Guru
Just my opinion but wiring and brake and clutch line placement first! It tends to lay under, around and through everything! Leave out lights and mirrors wires, flagged with tape ID tabs, for final assembly. Next Engine and trans. Then instruments, Pedals. Rack and steering column, then suspension. You can make up the suspension in "sub assemblies" on a work bench and set them aside until needed. (Place, but don't bolt down, the driver's seat; so you can sit and dream a little when time allows! ZOOM ZOOM!)Hello sir are you in N Orlando? Im from Orlando also 32824 you probably done by this time? I started on my Goblin chassis 443 doing harness and done with all panels,don't know what next to do front of the or back or engine i need little help can we meet o got couple of questions my phone 4074962105 Vitali
