Lechlis
- Lechlis Well-Known Member
More engine tear down pictures.
Notice anything different on the two piston pictures? The picture with the higher piston depicts cylinders 2-4. The piston that is lower is cylinder 1. I thought it might have been a bent rod, but I rocked the crank a little less than 1/8th turn and the piston didn’t move.... it needs a 1/8th or more rotation on the crank before the piston moves. So, the rod bearing has failed. I swear this thing didn’t make any abnormal noises and ran what I thought was on par for a conservative 7psi tune.
The rest are pictures from the head and oil pump. The cam journals are scored pretty well. The oil pump has a nice metallic sludge inside
I was hoping I could rebuild the head and block, but that simply isn’t going to happen at this point. We all know the bottom end is most likely a mess without even looking at it.
