Does anyone have any pictures of the manual shifter pedal box and what was removed? This is literally the only part that is still in my dash and it looks like the cylinder is riveted into the firewall.
How do you split the clutch rod from the pedal arm? There is a white tab on the back that I can push in and hear an audible click that makes me think once it is released it will release the clutch rod. I don't want to break it.
Just to follow-up on this.. You cannot push the white retainer clips together with the rod between them for them to release. They will not compress enough.
I did some googling and now it makes sense why yours didn't release like the others we've dealt with. Your donor had an aftermarket pushrod from ZZP (ZZP Adjustable Clutch Rod).
The stock push rod isn't as big where you have to squeeze the plastic clip. This lets the clip move in just far enough to disengage from the pedal. Compare the size of the shaft of the stock rod near the clip:
I see the stock pedal alignment has the gas pedal moved back 2". Has anybody tried mounting a block on the gas pedal or moving the pedal forward 2"? View attachment 7586
I also just noticed this when bleeding my brakes.. I drove a turbo cobalt for 5+ years and didn’t notice it the way I do now.. you literally have to lift your heel of your foot to get the brake.. doesn’t feel right
For several reasons I wanted to keep the stock fluid reservoir. So with that in mind it’s as simple as finding a suitable master cylinder designed for use with remote reservoir.
I'm not sure why Chevy decided to put the gas pedal 2" further away than the other pedals, but I prefer my 3 pedals to all be at the same level. Thus why you have to lift your heel to press the brake.
I would highly recommend you work on pushing the brake pedal back further instead of bringing the gas pedal out (which would be easier) because there’s already not enough room. If you have an extended chassis that may not apply.
I mocked up the pedals in the Goblin, and noticed that the gas/brake pedals are about 4" farther from the steering wheel, in the Goblin than in the Cobalt. I guess it is a more "lie down" seating position. Also the clutch pedal is now about 1.5" forward from it's Cobalt position, so now all the pedals form a diagonal line instead of being straight across. Guess I could put a 1.5" block on the brake, and a 3.5" block on the gas... but I will try the car this way before I attempt re-engineering it.
Mines hooked up fully and looks just like the above picture.
I don’t mind the clutch being there because the tube next to it makes a really nice foot rest. But I’m backing up the brake pedal to be equal with the gas
