I used one of the Motive Pressure Bleeder and open/close the bleeder a few times. Then I have my wife press and hold the clutch while I crack open the bleeder, close it and have her release. This is till with the pressure bleeder attached. About 5 times with her gets it done. Probably sooner but we go extra just to make sure it’s done.Watched a few videos how to bleed the clutch master cylinder, but actually I had to do it different. Just opening the bleed did not work. It sucked air back out of the hose every time i released the clutch. Then Open, push, close, release also did not work. I ended up using a syringe and sucked the air out of the line. Now, my question: If I push on the clutch the first 6-7mm (1/4in) of cylinder movement, I have no pressure until I can feel that the pressure increases. Is that normal or is there still air in the system?
Sorry for the delayed response. I will check my car this afternoon and see if I can figure out whether I did the same thing to get the trans to fit.Did you removed the LAP Temperature sensor from the LAP Thermostat housing or leave it in and just not connect it. If you removed it, how did you seal the sensor?
6 or 7 seconds won't hurt the engine if there's no coolant in it.That‘s it for tonight. I am charging the battery, I believe I sill have some air in the system. The engine was never running longer than 6 or 7 seconds, but it got hot already and I am worried that there is still to much air in the system. Since I can confirm that the engine is running, I will take it out again and change the clutch. Then install all the other parts again and will then later on deal with the idle issues I am having currently.
This was my exact method and I believe the most efficient way to bleed a Goblin clutch. Quick and easy on the upstream side of the bleeder and effective on the downstream side while maintaining the upstream fluid pack.I used one of the Motive Pressure Bleeder and open/close the bleeder a few times. Then I have my wife press and hold the clutch while I crack open the bleeder, close it and have her release. This is till with the pressure bleeder attached. About 5 times with her gets it done. Probably sooner but we go extra just to make sure it’s done.
Inserting an aluminum pipe at the bends, rather than folding the rubber, would be one solution. The 1.25 inch come in 45/90/135/180 bends.Another good day. Pulled the engine again, replaced the clutch and put the engine back in the car. Still a lot to do. Right now I wonder how to route the main coolant hoses. The radius of some corners are to tight. Anyone had good experience with 90 degree elbows?
Would love to see some LSJ coolant hose pictures of you guys.
Concerns about hose bends collapsing can be cured with an external wire spring, Goodyear and other hose makers offer them in stainless steel.Inserting an aluminum pipe at the bends, rather than folding the rubber, would be one solution. The 1.25 inch come in 45/90/135/180 bends.
HPS 1.25" OD 60 Degree Bend 6061 Aluminum Elbow Pipe Tubing 16 Gauge w/ 2" CLR | eBay
HPS 1.25" 32mm OD 90 Degree Bend 6061 Aluminum Elbow Tube Pipe 16 Gauge 2" CLR | eBay
In your pic it shows the purge valve for the vapor recovery system, it has the red with blue 2 wire connector and it has a hose running in and another running out of it. The hoses connected to it must be plugged if the vapor recovery system is removed/abandoned. Chase those two hoses down, they need to be complete or their original vacuum source plugged off. This is a possible vacuum leak.I bleeded the clutch again and again. Still the same. I will leave that for the moment.
Shifter cables are installed and routed. Fusebox holder in place and oil and coolant filled. There is still air in the coolant system, but I guess that will come out after driving the car for a bit.
Just to be clear, the engine never ran without coolant, even when I tested it a few days ago.
However, I have now the same issue with the engine not idling correct. I am not sure if the hoses are connected correctly. I try to mark the ends and wonder if someone could confirm that this is correct.
Ok, I changed the picture and added some numbers. Just want to make sure I do the right thing.In your pic it shows the purge valve for the vapor recovery system, it has the red with blue 2 wire connector and it has a hose running in and another running out of it. The hoses connected to it must be plugged if the vapor recovery system is removed/abandoned. Chase those two hoses down, they need to be complete or their original vacuum source plugged off. This is a possible vacuum leak.
How are you checking the oil for water? Looking at the dipstick? Unless the water has mixed with the oil - to make 'chocolate milk' - the water will sit in the bottom of the oil pan, likely below the level of the dipstick. If there is suspicion of water in the oil, draining the pan is the best way to identify if this has happened.
