Good idea, I have an IR camera.A lazer temperature gun pointed at each exhaust pipe when the engine is running, will tell if you have 1 bad injector, or cylinder.
If you don't have a lazer gun, you can see how long it takes a cold exhaust manifold to get too hot to keep your fingers on.
Great it was a simple fix!Problem solved. I looked at the not working cylinder and saw that the insulator came out and was stuck on the old injector.
I don't think so. I think the graph is the actual duty cycle. With the old injectors I was at 125% but only when I was at high rpm and high boost. It was short enough that my wideband sensor never picked up a lean situation.Neat.
So your graph numbers are half values of duty cycle? 31.8 in the graph equals 63.6% duty cycle?
If so...I need to lay off the boost until I get different injectors.
How would I do that?You need to confirm the injector math is correct for a 4 cylinder, unless HPT labeled a for a 4 cylinder. Since it fires 2x more than an 8 cylinder per revolution the duty cycle is double for a 4 cylinder for the same pulse width.
