I just can't think of any good place for them in the direct airflow.A trick to increase radiator/heat exchanger efficiency is a water mist sprayed onto the coils/tubes. Liquid is able to pull heat quicker from a metal surface than air. Plus the water has an evaporative effect that creates more cooling and can even pull temperature lower than ambient when the air very dry (like out here in the deser). But for this to work there must be constant airflow, otherwise the mist will over collect and 'puddle' reducing the evaporation effect. A puller fan is a bandaid for the constant airflow, but having the heat exchanger in the air stream is a better solution. Just something to think about.![]()
I had the chance to test it outside, it works as expected. It takes a little while to switch off the lights, but then the display is not dimmed and I can read it. I was just not patient enough when I pulled out of the garage.Are you in you garage or is it doing this outside too?
I drove it now for a few hundred miles and I don't like it. Especially when getting out of drifting. It just don't feel right. I'll add more caster. But it's for sure gives you a feeling driving on rails.I think a vehicle with no return to center on the steering is dangerous. I would add more castor.
Using this gauge, and measuring caster on one of these spots. Adam explains it here... better than I do.I can't speak to caster, since I haven't measured it and I don't even know what the best way of measuring it on the Goblin would be.
I have a little toe in front and back. I didn't record the settings, bit it's in the 0.2-0.5deg range.
