Bigfoot Goblin
If you get lucky the bullet holes are pointing the right way and work as windshield defog!Difficult to find reduced speed signs without bullet holes![]()
The overhang from the plexiglass sheet to the front is NOT representative. That was just to get the side pieces parallel. I designed the roof with a flange. That should increase the stability quite a bit, but I don't think I need that. The overhang distance from middle of the halo tube is 50mm.Not sure what you are shooting for as a final product but I think 1/16 inch aluminum is going to vibrate like crazy with that much overhang. And can you climb in with that side overhang?
Yes and no. The overhang covers any imperfection of matching exactly middle of the halo tube AND it provided more sun coverage. I like the way @Gtstorey overhang and roof looks like.If there's a problem with sun hitting you from the side - reason for overhang?
I wonder why my damper look so bad. @ToothMagician s look so much cleaner. Mine look like they were painted and the paint is chipping of everywhere.Not sure which picture you wanted to see. Damper, Seat or Brake Discs. So I got you all. You probably notice the newly added speed holes in the aluminum part under my heat exchanger
View attachment 50436View attachment 50437View attachment 50438
