Corgithulhu
- Corgithulhu Well-Known Member
The jury is still out on the above low speed data question. Lonny has been as busy as a cat with puppies, but as soon as I can ask him I will!
I have made some decent progress on the car though! I got the suspension and brakes in over the last few days. Definitely good to lean on the other build logs and photos on the website for the rear suspension. The front differs slightly from the front suspension and brake videos, but you should be able to follow along and get it done relatively easily.
Another electrical question incoming. So what we won't talk about is what kind of dummy I am for cutting out the turn signal switch connectors during the harness thinning. Someone obviously possessed my body and cut them out. I am in the process of fixing that demon's errors and have to wire the switch back in. Now that that's out of the way - I pulled the diagrams and it seems pretty straight forward since I found what wires on the switch go where on the BCM connectors (luckily we also realizedmy the mistake before taping the whole harness up and found the pink/white low beam relay extension and ran it up to the steering wheel area). The only question I have now is the signal wires. I found where they terminate in the wiring diagram, but is that just a simple body ground? Can I just run the black/white wires from the two connectors to the dash grounding lug, and that'll be valid?
The headlamp part of the MFS has the same illustration for the circuit 651 BK/WH grounding wire.
