What hose do you use on the brake reservoir use to connect on the brass fittings, Is it the same tube that you use to extend vacuum line to brake booster?
Also does the brass fittings simply screw into the aluminum block? Is there anything like teflon tape or other that goes in too?
Thanks!
Nuker-
