Re: Prototype 2: Track Goblin - 2009 LT donor
The stock Cobalt power makes for a surprisingly quick car (just ask anyone that has ridden in one of our demo cars) but we went and did the next logical step: we installed a power adder... specifically, the ZZP supercharger kit.
ZZP doesn't mention how much horsepower you will get out of the kit. Luckily, we've already dyno tested P2 without the supercharger (151 hp) so we can dyno it again soon to see the difference.
The kit comes with lots of parts (some of which we won't use). Most of the parts are straight from the supercharged Cobalt SS so they bolt right on to the stock 2.2 Ecotec.
The first step to install the supercharger was to get the stock intake and throttle body out of the way. You might see some differences between P2 and other kits (for example, P2 has the fuse box mounted in the wrong place).
The first piece to be installed is the intake manifold with built in intercooler. It is a water to air intercooler system that uses an electric pump to move the coolant from the intercooler to a heat exchanger.
Next you bolt on the supercharger. The ZZP 2.2 liter kit comes with a 3.4 inch pulley. If you go any smaller, you will probably need to replace your rods (preferably before they go through the side of your cylinder block).
We had to mount the supplied idler pulley differently than they instructed. Since the ZZP kit is generally installed on full bodied Cobalts, they assume you will have an AC compressor. We don't have the compressor on P2 so we had to reroute the belt. We made aluminum standoffs to put the idler above the alternator so that we would have a nice wrap around the blower pulley. We were able to buy a belt from the auto parts store to fit our new arrangement.
The last big hurdle was the heat exchanger. The supplied exchanger is meant to go in front of the radiator of a stock Cobalt. It is very big. Instead of using their exchanger, we decided to experiment with using the AC evaporator from the donor Cobalt as an. It is about 60% the size of the ZZP heat exchanger. We routed the hoses between the intake, pump and exchanger and filled it all with coolant. We also bought a 9 inch fan to keep air moving across the exchanger.
We don't know if the evaporator will be sufficient but this is the only car we plan to try it on. For other supercharged and turbocharged builds, we are going to run a heat exchanger at the front of the car with air ducts bringing in air from the control arm area. Water will run in tubes from the front, through the tunnel and up to the intake (supercharged builds) or to a water to air intercooler (turbocharged builds). P2 is a bit different up at the front so we couldn't try out this design.
We got a tune from ZZP and used HP Tuners to flash the ECM. The tune needs some tweaking but we will figure it out on the dyno soon. Even without the tweaking, the car is completely different now. It pulls harder from low RPMs and just keeps getting stronger until red line.
Anyone trying to decide between base model and SS should definitely consider going base model and adding a supercharger later.
