I don't like the look of the NACA ducts, though some people have done fine work to get them on the inside of the hood and looking good. I just use the fan ... but I live in PA, much more mild temperatures typically than what you'll deal with in FL. Also, I don't autocross.
I believe @JBINTX installed both the ducts AND a fan.
I like your scoop idea. I might try to move the air filter out later on. I thought about maybe running a small scoop underneath that helps flow air through the heat exchanger but I’d run the risk of picking up rocks and scraping. Maybe make it removable since I’d probably only need it for racing?![]()
Heat Exchanger Fan or Duct
Is there any consensus on which will provide lower iat2 temps for general usage (mix of tight backroads and in town driving but track driving not likely) for turbo? I'm working on finalizing my order prior to shipment. If the ducts can provide even slightly lower temps under "normal" usage, $225...dfkitcar.com
Scott @SACTX did some underbody work with a reverse scoop for an outlet.I like your scoop idea. I might try to move the air filter out later on. I thought about maybe running a small scoop underneath that helps flow air through the heat exchanger but I’d run the risk of picking up rocks and scraping. Maybe make it removable since I’d probably only need it for racing?
Jeremy you did not like the underglow lights either, but..............I don't like the look of the NACA ducts, though some people have done fine work to get them on the inside of the hood and looking good. I just use the fan ... but I live in PA, much more mild temperatures typically than what you'll deal with in FL. Also, I don't autocross.
Yeah I really like the 5 spoke wheels. I actually bought the jegs 15x10 ssr wheels too but they don’t have any tires yet.I like the cobra rims. Sorta like Ark's
I won’t lie I did get lucky with them but I wouldn’t overshoot and call them pristine. I just take pictures far enough back that the oxidation doesn’t show lol.I was initially jealous of Stretch for having access to a pristine set of the 2000's era Cobra wheels. I was looking for a set for months, but all I could find was curb-rash trash. I gave up and bought a set of Saleen replicas which I love, but were actually my second choice.
I just mean the DF air intake and shorter tube compared to the cobalt stuff. ThanksShouldn’t be a problem. I wouldn’t worry as much about running lean as stumbling at lower speed since the maf could probably need adjustment. Depending on what you mean by new intake.
