V2-006 Back From Powder Coat in Crystal Grey
V2-006
Written by Adam Doyle on Jul 3, 2026
V2-006 is back from the powder coating shop. It went out bare and came back in Crystal Grey with a clear coat on top. In the shade it is a dark gunmetal grey but out in the sun you see the bright metallic flake shine through. The clear coat gives it a bit more depth and makes for a more durable finish.
Goblin V2-006 chassis powder coated in Crystal Grey, sitting on a pallet outdoors, showing the T-Top main hoop, X-brace, and standard door bars
V2-006 back from powder coat in Crystal Grey. T-Top chassis with standard door bars and the Main Hoop X-Brace.
This one is a T-Top chassis. It has standard door bars and the Main Hoop X-Brace add-on. You can see the X-brace filling in the main hoop in the photo above. Here is the color up close so you can get a better sense of the flake.
Close-up of the Crystal Grey powder coat on V2-006 showing the silver metallic flake and clear coat over a welded chassis joint
If you want to follow along with this build, aaronc7 is documenting the whole thing in his build log: Goblin V2 (#6) - 2015 Audi A3 1.8 DQ250.
Adam Doyle
Adam is a co-founder and co-owner of DF Kit Car. He has helped hundreds of builders go from donor car to first drive, and is hands on with design, operations, and support. Outside the shop he's into auto racing and tabletop games.
