V1 SPECIFICATIONS
Goblin V1 Specs
The Goblin V1 combines lightweight design with powerful performance. Explore the specs below to see what makes the Goblin V1 stand out.
Powertrain Options
The Goblin can be built using different versions of the Chevrolet Cobalt, each offering unique performance characteristics. Whether you're looking for a straightforward, naturally aspirated build or a more powerful supercharged or turbocharged setup, there’s a Cobalt option to suit your needs.
The table below breaks down the specifications of the different engine options available, from the base models to the high-performance SS variants. Understanding these specs will help you choose the right donor to match your performance goals.
Base Sport SS/SC SS/TC
Displacement 2.2 liters 2.4 liters 2.0 liters 2.0 liters
Horsepower 145 - 155 171 - 173 205 260
Induction Naturally Aspirated Naturally Aspirated Supercharged Turbocharged
Transmission Auto or Manual Auto or Manual Manual Manual
Chassis Specifications
The Goblin's chassis is designed for both strength and agility, providing a lightweight yet durable foundation for your build. Crafted from DOM mild steel, the frame ensures safety and rigidity while keeping the weight to a minimum.
The table shows the key dimensions and materials used in the chassis construction, giving you an idea of the Goblin's compact yet robust design.
Spec Details
Length 127 in.
Width 52 in.
Height 44 in.
Material DOM Mild Steel
Main Cage 1.5 in. OD x .095 in. wall
Rear Cage 1.25 in. OD x .065 in. wall
Performance and Dimensions
The Goblin offers impressive performance and a compact design that enhances its agility and speed. With a range of horsepower options and a lightweight chassis, it delivers quick acceleration and a thrilling driving experience.
The table shows the key performance metrics and dimensions, showcasing the Goblin's capabilities both on and off the track.
Spec Details
Horsepower 145 - 260 hp (stock)
Weight 1350 to 1550 lbs.
Wheelbase 97.5 in.
Track Width 59 inches
0 - 60 MPH 4.7 s. base - 3.25 s. turbo
