V2-008 Back From Powder Coat in Illusion Spanish Fly
V2-008
Written by Adam Doyle on Aug 3, 2026
V2-008 is back from the powder coating shop in Illusion Spanish Fly.
The Illusion line is a two step application. A base coat goes down first, then the Illusion top coat over it. The top coat is translucent, so the base underneath still does work and the color you end up with has depth to it rather than sitting flat on the tube.
In this case the result is a deep metallic gold that shifts toward bronze and amber depending on where the light hits. Out in direct sun it goes bright. In the shade it pulls back toward a darker copper.
Goblin V2-008 chassis powder coated in Illusion Spanish Fly gold, sitting on a pallet outdoors, showing the T-Top hoop, rear cage X brace, and standard door bars
V2-008 back from powder coat in Illusion Spanish Fly. T-Top chassis with standard door bars, main hoop X brace, and rear cage X brace.
This one is a T-Top chassis with standard door bars. The builder also added the main hoop X brace and the rear cage X brace, both of which you can pick out in the photo above.
Here is the color up close.
The Illusion Spanish Fly up close. The translucent top coat over the base gives the gold its depth.
V2-008 is being built with a manual 2018 VW GTI donor.
Adam Doyle
Adam is a co-founder and co-owner of DF Kit Car. He has helped hundreds of builders go from donor car to first drive, and is hands on with design, operations, and support. Outside the shop he's into auto racing and tabletop games.
