jaredthenav
The gray wire there went to the taped union. Is that wire needed (for the info buttons, I mean)? I think Lonny said to keep the green white stripe and pink wires... Both go to the cluster plug.
You're awesome. Thank you!Yep. The other connector is for the “info” buttons. These will go to the gage panel buttons if you got that.
This is good to know (it's not hooked up). Tonight I removed the old starter and freshened up the wiring between the fuse box and starter. New starter should be here Saturday.The cobalt has “auto start”. So just a tap of the key and it will crank on its own until it starts. It could be doing a long crank because it’s not starting properly.
ho2s won’t keep it from starting.
pffft, that thing looks almost new. That's not very rusty there are still flakes of paint on it.Coming from somewhere where we never see rust, that’s like been in the bottom of the Gulf for years, type bad.
