Andrew, please don't try to use an incorrect bolt pattern hub. There is too much safety risk not having the hub studs centered in the holes in the wheels. 0.35mm (1/2 the difference in hub diameter) might not seem like much, but when the lug nuts are torqued to 80-90 ft.lbs. they will bend the studs inward and put radial stress on the studs. This is not good and under hard driving conditions may lead to snapping studs off.So onto the wheels, and specifically the bolt pattern.
I think I am most likely going to use Enkei RPF1 17x9s all around and will need 5x114.3 hubs.
At a little over 16lbs and a couple hundred dollars each, I don't think I can do much better.
As best as I can tell I have three options to got to 5x114.3
1. Drill the 5x110 hubs to 5x114.3
2. Use Adaptors
3. Change hubs to a 5x114.3 pattern
For #1, I don't like the idea of drilling the hubs partially because it makes me uncomfortable using drilled hubs in a track application, but mostly because bearings tend to be more of a consumable item when used heavily on the track. So I don't want to have to keep drilling out hubs when they need replacement.
#2. I could order some custom hub centric and wheel centric adaptors. I haven't made up my mind if this is ok or not. There are very opinionated people on both sides of this argument. I still can't decide if a 25mm adaptor would put any more stress on the bearings compared to a wheel with 25mm more of an offset. I don't think there are safety concerns with well made adaptors, just ware and tare and added rotational mass.
#3 would be ideal. It does not appear that that someone has found a prefect 5x114.3 hub for the LNF. The closest I've come across is an 04 Grand AM that has a 5x115 hub.
Searching through the forms it doesn't look like any Goblin owners have tried the Grand Am Hub.
Here are the spec of both the hubs.
Cobalt LNF Grand Am Spline Quantity 30 30 Bolt Circle Diameter 4.330" 4.530" Bolt Circle Diameter 110 mm 115 mm Flange Bolt Hole Quantity 3 3 Wheel Pilot Diameter 65 mm 70 mm Brake Pilot Diameter 65.4 mm 70.5 mm Wheel Stud Quantity 5 5 Hub Pilot Diameter 89.1 MM 91.4 MM Flange Shape Modified TRIANGULAR Anti-Lock Brake (ABS) Sensor Included Yes Yes Flange Offset 39 mm 36.9 mm Flange Diameter 137 MM 145 mm
The question also remains as to how well a 5x114.3 wheel will work on a 5x115 hub. Again, very opinionated people on both sides of the argument.
Are there any other reasonable ways to get a 5x114.3 bolt pattern?
Well said/explained DS, as always.Andrew, please don't try to use an incorrect bolt pattern hub. There is too much safety risk not having the hub studs centered in the holes in the wheels. 0.35mm (1/2 the difference in hub diameter) might not seem like much, but when the lug nuts are torqued to 80-90 ft.lbs. they will bend the studs inward and put radial stress on the studs. This is not good and under hard driving conditions may lead to snapping studs off.
Also noticed the Grand Am hub pilot diameter is 2.3mms wider, so it likely will not fit into the aluminum upright.
Thanks for pointing out the Pilot Diameter, I wasn't thinking about that and am not willing to machine the DF parts.Andrew, please don't try to use an incorrect bolt pattern hub. There is too much safety risk not having the hub studs centered in the holes in the wheels. 0.35mm (1/2 the difference in hub diameter) might not seem like much, but when the lug nuts are torqued to 80-90 ft.lbs. they will bend the studs inward and put radial stress on the studs. This is not good and under hard driving conditions may lead to snapping studs off.
I couldn't agree more! Seems like the RPF1s are 5-6lbs lights than an equivalently sized (and priced) 5x110. So I should still be coming out ahead if I end up going this route.Seems sort of counter productive to run a heavy spacer just to run a light wheel.
I came super close to pulling the trigger on these:I like Rauq's idea of having the wheels custom drilled to 5x110. Not sure if its possible, but its worth looking into!
hahah! I just found that website as well.I came super close to pulling the trigger on these:
https://www.fm-wheels.com/enkei-rpf1/enkei-rpf1-silver-17x9-5x110-22
I do like the idea of using the OEM housing, but the housing is designed to sit on the bottom of the tank, and there would not be room to install fittings from the pump to the Hydramat.I would pursue mounting an aftermarket pump with the Holley hydromat into the stock assembly first. If you look at the pictures of most of the aftermarket assemblies, they use hose clamps to fasten the pumps to the assembly anyway.
I think I have a spare fuel pump from my Camaro SS around and I think it might be the same size, and I'm sure there are aftermarket pumps that can be installed into that assembly.
Walbro 450 LPH Fuel Pump (overthetopperformance.com) shows it being "Flush mountable to existing hanger with installation kit 400-0085".
I haven't seen these before.The snowmobiler and rock crawler guys have solved fuel pickup issues by using multiple of these $26 pickups.
They automatically close after they run out of fuel. If you put one on each side of the Goblin tank, long as one side of the tank has fuel in it, you are good. A lot cheaper than the $225 Holley Hydramat, but a bit more work to install.
In my mind you would cut away most/all of the bucket and hang a new pump off the the stock hat.I do like the idea of using the OEM housing, but the housing is designed to sit on the bottom of the tank, and there would not be room to install fittings from the pump to the Hydramat.
I'll giving the housing a look and see if there is any possibility of modifying it.
I get where your going now.In my mind you would cut away most/all of the bucket and hang a new pump off the the stock hat.
