Nope error on my part. Thanks for catching.Andy, your signature says build #303, which brings me to your build thread Goblin #308.
Do you have 2 Goblins? Or is one of these a mistake?
Ahh that’s it! Thanks. Found on eBay. What is zzp?Clutch master cylinder. I broke mine as well. Bought a new one from zzp
Lol its as addictive as any drug or vice.It’s evil. You don’t want to go there.
That is what I was thinking. my tunnel cap was separate but if yours was placed down on top of the tunnel, it is a tight fit and may feel welded. bad news is that you will need to break the powdercoat and pull the cap off. You will need to run the positive power cable, your wiring harness, brake, vacuum, and coolant lines through there (all on the right side. You might have some explaining as to why your harness through the tunnel is so bulky. It should be about 20-30 small wires and be about 5/8" in diameter. Not he best pictures below, but that is with everything but the Auto trans cable on the left side and the booster vacuum line..How do I get the wiring harness through the frame? My goblin is different than the one in the videos. The tunnel came welded closed and the harness is too big to fit through the tunnel because there is a metal divider in the middle of the tunnel. I thought perhaps I could tape down the big pieces, but some of them are far too big to clear that metal piece inside the tunnel.
That’s probably it. I wish they would have included that information when I had it powder coated. It must really be on there tight.Any chance the cap was stuck in place and then powder coated? I’ve never heard of DF welding the tunnel cap.
