Yep. Just checking to make sure there wasn't a "better" way, that's all.If we have the same transmission. I think F35?
I don't know if this helps... Took me a minute to find this... but I remembered the Goonsquad guys used a pump. Check out this video at 15:57Rttoys, to go a little further with this ... is the best way to fill the trans fluid to remove the top hex bolt and use a funnel from the side? Seems kind of janky, but I haven't been able to find anything else.
Good to know. Let me know how the RMA process goes. Not a fan of shopping at sites with bad customer service.@Anks329 buyer beware, I discovered earlier that my wing is missing the green lead for brake lights as shown in the pics on the site. As it stands, my wing won't function as a third brake light. I've got an email in to their tech support, hoping for an RMA/replacement control module.
Jeremy: Yep. Drain from the bottom. Fill in the top. Make sure you are on level ground when filling.Rttoys, to go a little further with this ... is the best way to fill the trans fluid to remove the top hex bolt and use a funnel from the side? Seems kind of janky, but I haven't been able to find anything else.
or stick a piece of rubber hose on the end of the squeeze bottle. That is if it has a nice little point filler top.Jeremy: Yep. Drain from the bottom. Fill in the top. Make sure you are on level ground when filling.
Good!!!!
I like the one with the mustangs lolMini update.
Rear suspension is built (have to check torque values though), taillights mounted but not wired (need to resolve a problem with the third brake light on my wing), and back wheels test-fitted with brake rotors on. I need spacers, but I figured I would.
Next is rear brakes (paint and mount), attach and plumb the turbo IC, and figure out how to wire the tow kit.
I am contemplating putting this on the Goblin, somewhere/somehow, though I'd want it in color:
Or this one:
I was also thinking the Shelby-esque color scheme, and with that sticker its like putting salt in a wound when you pass a new gt by.Me too. Not sure how appropriate it is though, since I've owned 6 Mustangs including a '69 R-code Mach 1 resto project (well, technically my dad's), and the theme I have decided upon is Shelby-esque.
oh heck yes! My son wanted me to get custom plates - V8EATER. His mom drives a Mustang GT.....Me too. Not sure how appropriate it is though, since I've owned 6 Mustangs including a '69 R-code Mach 1 resto project (well, technically my dad's), and the theme I have decided upon is Shelby-esque.
Or, "I8 A V8"oh heck yes! My son wanted me to get custom plates - V8EATER. His mom drives a Mustang GT.....
