Jareth
I’m in the same predicament, do aftermarket seats work with the stock sliders?Not sure yet.
To late. Already picked one upWell don't buy a rivet gun. You can use this one when the time comes
Paul which methanol system did you install?Methanol port injection:
For the port injection plumbing I used ProMeth:Paul which methanol system did you install?
Sounds good. That will be compatible with the new clutch break in.I posted something about it a while ago but can't seem to find it. In short, easy on the throttle (50% or less) and keep boost low during the first couple hundred miles. If everything still feels good add some more throttle (75%) with a few short full throttle bursts over the next couple hundred miles. By the time you get to 500 miles it's time to change the oil and filter to look for an metallic particles - use a clean magnet. After that you should be good to drive it normally, but I wouldn't go racing until a few more hundred miles are on it ensure everything is seated properly and won't come apart.
I sent the intake manifold to Rodney at ProMeth and he did the installation. This is the setup I ran on my Solstice. I originally ran a single nozzle right before the throttle body which worked fine but I was chasing a little bit of intermittent KR that would show up on isolated cylinders. I was hoping the direct port setup would even things out and take care of that but it didn't really make a difference. I got a great deal on a couple cases of Boost Juice a while back so I still have a bunch of that.I was just looking at this port injection setup! Looks fantastic.
Was the meth port injection a direct install or did you have to adjust the nozzles to line up with the middle of the runners?
What nozzle size are you running?
Straight meth or mix?
Are you taking it somewhere for the tune? If doing it yourself, what is the approach when introducing meth? Higher timing and less fuel by a %, starting to spray at 18psi etc.
