Nice cruise. Bet there are a lot of people going the other way wondering what the heck that was they just passed.
We took a 750 mile run over last weekend and one case got the best look over of all. We where flying down the freeway at 75ish and passed a horse trailer and crew cab pickup with a dog hanging out the back window. That dog watch us pass by with such a look we thought he was going to jump over into our car lol. I am sure once we passed by he ran up to the farmer and said we gotta have one of them there cars.Nice cruise. Bet there are a lot of people going the other way wondering what the heck that was they just passed.
We have discovered that you wear problems on the outside because they seem to blow off when you take a drive like that one.Wow. That is pretty country. Looks like you had fun!
Now we have 2 dumb sobs playing with stuff!Okay I got my hptuner yesterday. I pulled my base file saved it then looked through found where I could change tire size and change how DTCs where handled by ECM. Made those changes (all evap codes) now I don't have any zip in 1st and 2nd but look out for 3rd. So I figured I f***ed up reflashed old file figuring that should fix but the problem still exists any Idea. I know some dumb sob playing with stuff he should not.
My 2006 Cobalt has a clutch switch for the cruise (which I removed) and a 2nd switch for the engine start.Okay here is another hint. Runs great with clutch in let clutch out problem. So disconnected the clutch out switch and she keeps your head pinned to the seat runs like the wind
Any clue as to what I messed up. The only reason I put that switch back in was for cruise
Almost positive you have the F23 transmissionYes I have the f35 trans and that is what I thought to was that the ecm had no way of knowing what gear it was in. Temp has no bearing to problem as it does it from cold to 190 which is it normal run temp. I am wondering if the after market cruise put the ecm into limp mode and if I have a problem with the unit because I have had a P0606 code pop up during this adventure as well so I am going to run with both unplugged for a bit and see then plug switch back in without after market cruise. But it seems funny that this limp mode only happened when I played with files still makes me think it is something I did somewhere. I was careful so I thought as to not mess with things I knew nothing about.
But test run last night with switch unplugged was the best it has ran since I put switch and after market cruise in. Back to the Holy Crap that car moves.
You may be correct but I believe ECM still really has no clue as to which gear we are in.Almost positive you have the F23 transmission
You are correct. sent you a pmYou may be correct but I believe ECM still really has no clue as to which gear we are in.
ok here is the first file pulled from my ECMYou are correct. sent you a pm
Okay you lost me here for a second STFT? And LTFT? Once you tell me I know I will slap my foreheadI took Killa B's stock file, and copied the 'stock' settings to your tune file goblin62420c.hpt to make you a new file that is stock, and for your PCM.
This should return you PCM to a stock tune.
You will want to reset your STFT and LTFT if you try this in your PCM.
