Ok, I'm probably being a worry wart... but I want to run this past you guys.
I have forged internals now. Yay. The entire car is being built to be able to handle just about as much power as the block/crank will handle. That limits me (to my knowledge) to around 450hp. Right now I'm just running an m62, so that's no where near a concern. Eventually I'll probably go twincharged, or just a Z54 or whatever.
That brings me to my question. Did I mess up with ring gaps? I'm about to put timing chains on, so I would rather disassemble and regap now if I have to.
I don't have the original Wiseco instructions, so I looked them up online. I found this:
I aimed for Circle Track/Drag Race because I'm ok with loosing a little bit of power to blow by if it means I'm safer.
I was watching a Youtube video just now and I saw the guy pull up this chart:
There's a lot more detail here. With the M62 I'd fall in the "Mild Boost up to 15lb" category. Comparing that to the other chart, and what I gapped them to is basically spot on to that (slightly tighter second ring but close enough). If I go turbo/twincharged though, that would put me in the medium boost category, which has a much (4-5 thou) bigger gap.
Am I being paranoid, or am I right to think that I should probably take them back out and gap them a bit more?
