Don't believe the Dorman parts are better than other parts - they may be coming from the same parts source in China anyway - so saving a few buck is probably the way to go.
I am getting ideas for when I order my kit. Quick question though. Is it really easier to sawsall the front end off to pull the drivetrain? I was planning on wrapping my chain hoist to the support, sticking a couple movers dolly's underneath, unbolting everything and just lifting up the body and roll it all out from underneath.I finally finished the first point of no return portion of the year downView attachment 39758
Now I got a bunch of labeling to do on the harness. Everything unplugged so far I remember what it is but time to do it right before I forget. I’ve been holding off because it’s tedious and boring.
I cut the front beam out before I was ready to drop the engine and found it made getting to some parts easier for disconnecting them as well.I am getting ideas for when I order my kit. Quick question though. Is it really easier to sawsall the front end off to pull the drivetrain? I was planning on wrapping my chain hoist to the support, sticking a couple movers dolly's underneath, unbolting everything and just lifting up the body and roll it all out from underneath.
Yeah lots of things are causing the lack of motivation. Just didn’t feel like going into details.Idk about you but the heats not helping. Lots of other things in my life have changed my focus for now. Motivational changes, I feel, are bound to happen at some point. Life gets in the way. Keep at it and if you need a hand lmk.
I used self etching primer. I even painted it inside the warehouse at work minimize humidity.Painting aluminum shouldn't be much different than anything else. Self-etching primer might be a little better, but If you had it clean, it shouldn't have been a problem with regular primer. Or even krylon spray prime/paint in one should have worked ok.
Wait, do you actually have some of my tools !?! HahaHeck yeah! I'm holding some of his tools hostage, so there's no getting rid of me
