I think a read that someone cut an aluminum panel and then glued the floor mat to that panel. I was thinking of doing something like this, but I'm not to that point yet.Thought about trying that but I don't think it'll stick to the stuff I painted the floorboard with. Maybe I'll give it a try.
I'll give this a try. So you basically pulled the "L" cable further away from the shift arms?To get 5th and reverse , what I did was tighten bottom nut on left cable up about 3/4“ and if you still don’t have reverse shorten up drivers side shift rod a little at a time until you have reverse
Try silicone. It sticks well to most things and is not too hard to clean up.Speaking of dust and dirt on the floorboard, that reminds me. I bought a floor mat from Lowe's and cut it to size as floor mats for my car. Getting in and out of the Goblin is a challenge, and if I get in wrong, I end up kicking the mat forward and jamming it up under the pedals.
Any suggestions for a way to keep the mats stationary, but removeable? Like, I don't want to affix them to the floorboard, but I want them to reasonably "stick" where I want them. Maybe like a spray-on tacky substance?
This sounds involved but it's an easy project. I cut some cardboard for the general shape, then got some 1/8" plate steel and cut that to the shape. I then went to a big box and picked up some 24x36" matt (aisle 36 at my lowes) and liquid nails. Spread the liquid nails on the 1/8" plate, placed the matt down on top and then cut around the plate. I used the matt on both sides of the plate. $17 for matt and liquid nails + 1/8" plate (I already had). You're looking at maybe $40 for both matts - solid, hefty enough it doesn't move, removeable, good looking, durable, cheap to fix if they get goofed.Speaking of dust and dirt on the floorboard, that reminds me. I bought a floor mat from Lowe's and cut it to size as floor mats for my car. Getting in and out of the Goblin is a challenge, and if I get in wrong, I end up kicking the mat forward and jamming it up under the pedals.
Yes and then adjust left shift Rod shorter a little at a time to get reverse if you don’t by shortening left cable on trannyI'll give this a try. So you basically pulled the "L" cable further away from the shift arms?
Yes could be air. I had to bleed mine three times before all the air worked out.I can't seem to get the clutch to engage. When I turn the car on I can't seem to get it in gear. I don't want to force it. With the engine off and in neutral I can roll the car forward. then I press clutch and brake and put it in 1st(car still off) release clutch and brake and does not roll... Good so far. still in 1st gear and push the clutch in and still won't roll. Clutch pedal springs back and feels like pretty normal pressure.
Any tips?
Could it be that I still have air in the clutch line?
Did yoy install aluminum fllywheel?I can't seem to get the clutch to engage. When I turn the car on I can't seem to get it in gear. I don't want to force it. With the engine off and in neutral I can roll the car forward. then I press clutch and brake and put it in 1st(car still off) release clutch and brake and does not roll... Good so far. still in 1st gear and push the clutch in and still won't roll. Clutch pedal springs back and feels like pretty normal pressure.
Any tips?
I did not.Did yoy install aluminum fllywheel?
Brad
I will try to bleed it again. thanks.Yes could be air. I had to bleed mine three times before all the air worked out.
Interesting.I have been working with this type of slave cylinder for over thirty years. Attached is instructions on how to pre bleed the slave cylinder before matting to engine. There are different variables you car do but the idea is the same.
Brad
You have the tie rod ends set with similar thread showing but is the steering rack actually centered? If you turn full left and full right, are you getting the same number of rotations of the steering wheel from where you’re calling center?3. Alignment: I have the wheels on and the car on the ground! I did the rear alignment, seems to have gone as planned. Now I'm working on the front... Here's where I have a big question. At the start of my build I replaced the inner tie-rods that connect to the steering rack. Now the driver side wheel is really toed out when I have the tie rods set with the same about of thread on both sides. It looks to me that the driver side tie rod is one inch shorter than the passenger side. Any ideas how i screwed this up?
I am yes. If I remember correctly I think I get 1.5 turns in either direction.You have the tie rod ends set with similar thread showing but is the steering rack actually centered? If you turn full left and full right, are you getting the same number of rotations of the steering wheel from where you’re calling center?
I seem to remember checking that they were the same length.Have you measured that the inner tie rods are the same length? I have no idea why they wouldn’t be, but it’s one of the things I do when replacing stuff, is see if it’s a direct match.
And just Incase it was missed or overlooked; the factory outer tie rods go on the back of the goblin and DF supplies you with new outer tie rod ends for the front that are shorter.
Hhmm. Did you mix these up maybe? Just thinking out loud.
