That reminds me of when I was younger I build a Camaro and had to wire my fan to a toggle switch. I took power from the wrong spot and if I had the fan running when I turned the ignition off the car would stay running. Once I moved the power wire the problem stopped. I’m wondering if you somehow have the cooling fan back feeding power to the ECUOkay so some weird ass ****.
I never realized before that when I turned my key to power the radiator fan also started.
I put the new ECU in turned key to power and the fan kicked on and turned off after about 10 seconds. I put the original ECU in and the fan no longer turns on when the key is turned to power.
I have also observed that the purple wire is no longer showing +7-11volts since the fan stopped turning on. I checked the fan 30a fuse and it appears fine.
tomorrow I’ll reconnect the purple wire and see what it’s reading but this is really weird.....
Nuker-
Isn’t the fan one of the things that is a variable that can be changed in HP Tuners?Okay so some weird ass ****.
Nuker-
Looking good. You may want to put some kind of heat shield on the charge air tube coming out of the intercooler. It looks like it's about 3-4 inches from the exhaust pipe and the up to 1200 degree radiant heat will really warm up your charge air that you are trying hard to keep cool.
I just put mine on and ran the nut down. The Crome adapter bolted right over the top of it. The center is tight around the nut but fits.Got a bunch done tonight, brakes and clutch bled.
Started on the steering wheel but the DF quick release does not seem deep enough to connect to the spline adapter after you out the nut on.
Any ideas?
Thanks!
Nuker-
