2.2 VVT
3.0 Pulley
60lb Injectors
LSJ throttlebody
This is my Wide Band I have it hooked to the serial output so I can data log it in HPT. ( I'm pretty sure that the guy from ZZP did not even care that it was being logged.)
I need to get the dual pass or this winter make something similar to This single pass setup The cooler is doing a decent job but I am heat soaking it after long runs.
Not to necro an old thread... but do you guys think I would be able to use Karter's old tune he provided in the post above to get mine going? Obviously it'll still need tuning, but it would be nice to have for basic testing (ie does it run, leaks, sensors, etc. Not looking to rip it). It looks like we are running basically the same thing. I'm running the same setup he had listed, but with a 3.1 pulley instead of a 3.0. Thoughts? I don't see why it wouldn't work as long as I stay out of boost.Ok here are my last 2 log files from after the 5th tune. I know I have some high IAT's working on that. And the final tune
As a base, it should be fine.Not to necro an old thread... but do you guys think I would be able to use Karter's old tune he provided in the post above to get mine going? Obviously it'll still need tuning, but it would be nice to have for basic testing (ie does it run, leaks, sensors, etc. Not looking to rip it). It looks like we are running basically the same thing. I'm running the same setup he had listed, but with a 3.1 pulley instead of a 3.0. Thoughts? I don't see why it wouldn't work as long as I stay out of boost.
ShhhhhhhAs a base, it should be fine.
@Mayor West used one of my tunes to get up and running as our mods were similar. He did rip it though lol
