Fuel tank?
What cha makin?!?!Progress from the fab shop. They said some of my measurements were only off by a 1/16". I feel pretty proud of that.
Glad I'm not the only one wondering! Water tank maybe?What cha makin?!?!
What gage steel did you use for the plate to mount the pedal box? I'm thinking about using 14 gage.So the Goblin has been on the back burner. I did bring it home almost 2 months ago. I did find a new job shortly after and am still there for the time being, but it is not covering my bills and is not going to work out. But I did just recently get hired with a new company and I can potentially make more than I ever had before if I am successful at it, but I have to take online classes to get licensed before I can officially start. I was never really a morning person at all, but it is amazing getting up at 5-6am after working from 6pm to 6am for almost 8 years
Here you can see a bunch of what was done. Windshield frame, side pods, new dash bar, harness bar, flat stock to mount the Kirkeys, and upsidedown steering column mount(will get fixed later on when they stop by to add mounting tabs for coolant/heat exchanger tanks and other misc stuff.
Close up of the top of the windshield frame. Still needs some massaging. It is flat stock welded onto a round tube and filled with weld on top to smooth it out. The mounting lip for the windshield is recessed 1/2" per recommendation of my local glass guy who will be doing the windshield. 1/4" for the glue and another 1/4" for the glass itself and hopefully it'll sit flush.
Extra square tubing in the floor again and flat stock to mount the Kirkeys to.
All I can tell you is that it is ~1/8" thick.What gage steel did you use for the plate to mount the pedal box? I'm thinking about using 14 gage.
From personal experience of about 110 miles on a tank with e85 it would be nice to have 15 gallons for a group ride.Tank fits. It is a bit tricky to get in and out. Definately not possible with the engine/trans/subframe installed. The fuel fill will have to be moved again to basically the "OEM" location, but on driver side instead of the passenger side.
Compared to the stock tank.
I also calculated it's volume by filling some old gallon jugs with water and dumping them in. I confirmed that the stock tank is 9 gallons.
I might be able to sneak another gallon into it, but I stopped here to allow room for the FCST. So I feel safe saying that 15 gallons is an accurate number.
It would be funny if it weren't so true.From personal experience of about 110 miles on a tank with e85 it would be nice to have 15 gallons for a group ride.
Soooo you’re in the market for a roof rack and fuel cans is what I’m hearing?From personal experience of about 110 miles on a tank with e85 it would be nice to have 15 gallons for a group ride.
Another reason I wish I went with the track frame.Soooo you’re in the market for a roof rack and fuel cans is what I’m hearing?
