Adam in CLE
- Adam in CLE Well-Known Member
Hi All. Been talking to gtstorey quite a bit who has been a great help. I am posting for 2 reasons, the first is if someone else has the issue hopefully they find this. The second is to gather a general consensus of ideas. Thought I was ready for the 1st drive but ran into some issues. Brake pedal goes all they way down. Through research found 2 things out. 1, front caliper needs the bleeder pointing up (complete oversight). 2, if that doesn't fix it, I will be buying a new master cylinder. The other issue is I am leaking brake fluid where the engine and transmission comes together. I am bone dry where the clutch line gets connected. The fix is pulling the engine and replace the throw out bearing. While in there I may do the rear main seal if needed. If anyone has had this issue have you fixed without pulling the motor? Also welcome other ideas on where the issue is.
