V1 Dakota8800's City Goblin! - 2005 Cobalt SS/SC
The back going to the engine
Oh. And yes, grab the park brake stuff. You’ll probably want that and it doesn’t take much to install it.
JeffsGoblin
Use high pressure (60psi or higher) rubber fuel hose to clean up the the fuel hose routings. Cut the ends off the stock hoses and attach them to the rubber hoses. I also cut the plastic line off the car from the quick disconnect on the engine to the metal line going back to the fuel tank. I spliced that in for a clean look from the filter to top of the engine.
yep, a clock spring for the air bag. Not needed.
I did something similar on my build:
16063
16064
Dakota8800
Looks good and seems easy enough. Thanks!
Goblin Graber
If you want to save money not powder coating but want a durable finish I suggest top coating the paint on your chassis with 2k clear. Comes in two part rattle cans. You just release the hardener from the bottom of the can, shake, and spray real 2 part clear.
I paint matched the lower fork legs and side covers on my buddys Dyna 5 years ago this way and they are still holding up good.
