Well I guess I've sorta neglected the build log here since the last I've made a big update. The goblin is running and driving and is scheduled to be street legal before the nice weather rolls in! I have no idea how I'm gonna structure this post but I think I'm just going to upload the photos, videos, and info in order as it is on my phone and figure it out as I go...
To start out, I guess I jumped into finishing the car after the wiring harness pretty quickly. Everything just clicked together like adult Lego for the most part. I decided to jump onto the road/track with a set of Nitto NT01 245/45ZR17 tires on some 5x114.3 17x9 +40 Konig hypergrams. Side note for anyone deciding on wheels and tires, a 40 offset is dangerously close to rubbing the rear suspension when running the BC coils. I ended up putting some 10mm spacers to clear the shocks but it is still pretty close and definitely does not leave enough room to mount the fenders. According to the dates on the photos I had the first ever drive in the goblin on May 29, 2022. I proceeded to cut it close and run to my first autocross June 4, 2022. The first drive was short, but I was hooked almost instantly. I definitely still needed a lot of work as the rear brakes were grinding and the engine was freshly rebuilt/upgraded with a stock tune on it. The car was very touchy on the throttle and would start to buck and oscillate violently when trying to drive at low speeds. With a little over a week I jumped into learning the tune the car myself. Long story short, I was in way over my head... Worked with a recommended cobalt LSJ tuner to dial in the MAF using LTFT (long term fuel trims) and STFT (short term fuel trims) which made a huge difference in the bucking but there was still a bunch to go. My biggest problem with the tuning was the lack of a wide band O2 sensor which I will cover later.
Finally! The moment I've been waiting for! Getting onto a track to race this beast. Photos make it look great however, I was slow, a novice, poorly tuned, broken down, and every other adjective you can think of but I didn't care. I brought my homemade racecar to drive at an event. It didn't matter how much trouble I had because everyone at the event and on the forums was super helpful and supportive. Not only that, nobody in the area had ever seen a goblin and I made lots of great friends. Oh, Did I mention that I spun the thing on my very first lap out... Learned in that moment I need to seriously learn how to drive this car and be mindful of what It can do and how quickly it can go wrong. Glad I learned this lesson on a closed course.
Wish I had a better camera for my first autocross event so all I've got are spectator views. In short I learned at the first event to work on my throttle control, smooth steering inputs, the supercharger sounds amazing but easy kicks the tires, and that I had a severe oil leak coming from where the bell housing connects to the engine.
Forum only allows the posting of 20 photos at a time so I am going to start another post right after this one!
