David
- David Goblin Guru
Ok got everything back together and no leak. So that was definitely the problem, but snice nothing is easy.
Now I have an issue with intercooler pump popping fuse when I plug it in. Also plugged in HP Tuners and not reading oil pressure. No low pressure light on the dash.
Have CEL for P0463 low fuel sensor A Circuit, snice im not using the factory fuel pump assembly. Also P0532 A/C Refrigerant pressure sensor A Circuit Low.
Can those error code effect oil pressure sensor?
What should be my next step?
Forgot to mention P0532 is disabled
