- No. Is there something specific you are trying to fix by switching the springs? I tried several setups, and 300 on rear feels right. I did switch to
progressive springs on the front, just to soften the first inch or so of travel.
Nothing particular at the moment that springs will change. Just figured ill ask snice I read some guys switching.
- Is your steering wheel close to centered? If so, I would turn the wheel straight, then adjust the tie rods. If you adjust the right 1 turn in, then adjust the left 1 turn out. Keeping the number of turn the same will keep your tow-in setting the same, and preserve your wheel alignment.
Its some what close, when you drive its towards the left. I'll say guessing around 30⁰, thats the reason I thought it would be good to check. If the steering rack or power steering needed to be checked.
- Run the lower control arms level, both front and rear. With those big 18" wheels, your ride height will be different than mine.
Meaning the lower control arm screwed all the way in ?
- 16 to 18 PSI front, add an extra 2 psi for the rears. Use the chalk method to check if the tire pressure is right for your tires.
Would pressure change the alignment specs or corner balance? Meaning does it matter snice its a base line. I know alignment is going to be a journey but trying to not chase my tail to much.
- front: -0.5 camber, 8 caster, 1/8" tow in, rear: -1 camber 1/8" tow in. I have seen variations of these numbers, but this is a good starting point.
