Nice work!E-Brake/Parking Brake - Unfortunately I did not save my E-Brake hardware so I had to build it from scratch. Did not see much info on here so I took a lot of pictures of what I did. The E-Brake handle is readily available (Ebay) as are the cables (Rock Auto). The rest I had to cobble together. As we say in the Navy "Works great, failsafe & it drains to the bilge".
Looks familiar...Needed to add some USB charging ports. Found this nice piece that has an On/Off switch, a DC Volt readout, two USB charging Ports & a cigarette lighter socket (for Camera or Radar detector). Pretty easy upgrade & looks nice. https://www.amazon.com/gp/product/B0741C4F78/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
I think your setup looks way better than the stock tubes..E-Brake/Parking Brake - Unfortunately I did not save my E-Brake hardware so I had to build it from scratch. Did not see much info on here so I took a lot of pictures of what I did. The E-Brake handle is readily available (Ebay) as are the cables (Rock Auto). The rest I had to cobble together. As we say in the Navy "Works fine, failsafe & drains to the bilge".
Nice job FrankE-Brake/Parking Brake - Unfortunately I did not save my E-Brake hardware so I had to build it from scratch. Did not see much info on here so I took a lot of pictures of what I did. The E-Brake handle is readily available (Ebay) as are the cables (Rock Auto). The rest I had to cobble together. As we say in the Navy "Works fine, failsafe & drains to the bilge".
Did not see that. Another good location for that panel. Looks good !Looks familiar...![]()
As far as I know both are required. There is an exception But I'm not sure how to get it. Probably can drive without it. You could always say "must have fallen off"Is it a requirement to run both rear and front plates?
