V1 Mikes Extended, Full Frame Goblin - 2009 Cobalt LS with 135k donor
M
I got the new pulley from @Robinjo. Pulled it off the hub and was wondering if the hub currently installed on my Supercharger has the same diameter. I can't measure the diameter with the current pulley installed. Does anyone know if they are the same?
M
Question to all SS SC guys, how large is your intercooler, active or passive cooled and in the front or back?
I am using a motorcycle radiator and have 2x12V fans blowing on it. Mounted above the gas tank between the seats.
I think I could use a larger radiator.
You could probably use cooler air. We are talking about fairly low temperatures and the warmer air around the motor may mean that the temperature difference isn’t enough no matter how big the heat exchanger is.
M
This is my current set up. I don't think the air is terrible warm. The fans blow from the front to the back.
I have somewhere an IR picture of the radiator and I was wondering that I can't see a temperature difference between inlet and outlet.
45602
45603
I do keep forgetting that you are sc. So you will have higher temperatures when things are heat soaked after sitting hot. How quickly does your iat come back down after you start up again?
Just run it, you aren't going to hurt the engine. A good number of SC Cobalts are running without a working coolant pump in the intercooler system, and the PCM protects the engine by reducing the power. After a hard run in the goblin, touch the heat exchanger and see if it is getting hot. I can only get mine warm, and that is at race track. If you are running a turbo or a 2.6" pulley on your SC, you may find that the intercooler needs help, but the stock SC isn't that big of a heat generator.
M
Yeah, that's right. But I want to make it as easy as possible for the engine and get prepared for making more HP. The heat exchanger currently gets only hand warm. Nothing to crazy. I think I measured around 100F.
M
First iteration of a shift indicator. Now I need to find out how to read that from the can bus.
I have radiators everywhere on my bench to be tied in for better cooling. Dirt bike ones are usually split so you can put a bunch of small ones in different places. Also have the zzp add on cobalt intercooler that I’ll adapt sooner or later
@Gtstorey not quite sure what you mean. But I made some runs and monitored the IAT, IAT 2 and set up a user parameter IAT2/IAT.
Not sure about what part?
A larger radiator isn’t going to make a big difference in temperature. If you are. Trying to cool 100 degree radiator with 85-90 (or hotter during summer) air, you aren’t going to be able to drop the water temperature much without a major increase in radiator and airflow.
Look up supercharger heat soak. Basically the hottest water you will see is after the car is turned off on hot engine on a hot day. The non circulating water setting on top of the engine will approach the actual engine temperature.
M
My intercooler pump and the fans are currently run by a simple switch, that allows me to run it even if the engine is off and pull out heat from the system.
But, I can test it and switch it off with the engine. Do you have any guidance what temperature drop is good or bad and in what time frame?
No. You just typically want to stay out of boost until it comes back down to “normal”
A trick to increase radiator/heat exchanger efficiency is a water mist sprayed onto the coils/tubes. Liquid is able to pull heat quicker from a metal surface than air. Plus the water has an evaporative effect that creates more cooling and can even pull temperature lower than ambient when the air very dry (like out here in the deser). But for this to work there must be constant airflow, otherwise the mist will over collect and 'puddle' reducing the evaporation effect. A puller fan is a bandaid for the constant airflow, but having the heat exchanger in the air stream is a better solution. Just something to think about. :D
Even faster is nitrous oxide across the heat exchanger or intercooler.
