V1 MJP61 Street Goblin - 10 LS Donor - #297
MJP61
Installing the brake master cylinder relocation lines this morning. Does it matter which line goes where from Resevoir to master?
Doesn’t matter. The res is just feeding fluid to the master. I think everyone matches original location, just because.
Congratulations. First start level achieved.
Nice matching gauge set... where did you get those?
MJP61
Are the colored Gauge Face difficult to replace?
Not at all. Just have to carefully remove the plastic cover and pry off each needle. My dash kit came with directions. Very simple to follow.
Jareth
Guess some remove the gauge faces temporarily just to tape over some of the LED’s? So might as well replace them with some color matched ones.
Just as easy as covering the lights you don’t need anymore.
MJP61
So I installed the DF Steering wheel tonight. I know some guys had a little play in theirs, but mine has a lot. Any insight into what I might have done wrong?
I didn’t use this silver ring. (Not sure where it would go)
Steering Wheel Play
