- ctuinstra Goblin Guru
The 07 (with the P12) don’t support CANBUS O2 that’s available. That’s why I had to use the analog.I have the MPVI2 version, but if you want to use an analog AFR gauge then you have to use the side adapter plug and wire the AFR to that. If you use a digital one, you get the serial to usb and wire the AFR sensor to a serial>usb adapter and plug straight to the PC, then set HPTuner to utilize that as a secondary input if I’m understanding @ctuinstra correctly.
