Bigfoot Goblin
Just my 2 cents: with the heater core connected, having the coolant outlet from the engine close to the exhaust header would be a benefit to put more heat into the heater core - radiant heat from the header will be transfered I to the aluminum tube. It should also be noted that having the heater core in circuit did act as a small radiator, returning (slightly) cooler fluid back to the engine. Putting a hose loop on the pipes will not remove any heat from the heater core loop.
In our case building the Goblin, having this (minor) source of extra radiated heat from the header getting into the engine coolant - with these two pipes looped. Since I'm in the desert, any time a source of heat can be removed, cooled or bypassed, it will be done and was the gist of my response. In my case, removing the tubes, taping the ports in the t-stat housing, and installing AN fittings will be a must. I plan to have an additional cooler in this circuit, that will mimic the Cobalt heater core, to remove more heat from the cooling system. This is just information for other Goblin builders to consider, especially anyone living in warmer weather.
Sorry for the hijack.
