Goblin V2 Donor Parts List
Last updated: Nov 5, 2026 by Adam Doyle
This list covers the major components you should save or remove from your Mk7 Golf or GTI donor when preparing for a Goblin V2 build. It is subject to change as we finalize production updates.
Parts You WILL Need
Powertrain Parts to Keep
  • engine
    • intact intake manifold
    • throttle body
    • turbocharger
    • coil packs
    • all hoses
  • transmission
    • transmission breather hose and box (not standard on all transmissions)
  • powertrain harness
  • ECM (engine control module)
  • fusebox
  • battery tray
  • air filter box
    • lower and upper portion of the air filter box
  • air intake pipe from filter to turbo
  • charge pipe from turbocharger to intercooler
  • charge pipe from intercooler to throttle body
  • coolant tank
  • pendulum mount
Front Suspension, Brakes, and Steering Parts to Keep
  • steering rack
  • steering column
  • ABS module (added 6-17-2026)
Miscellaneous Parts to Keep
  • main/body harness
    • Save all harnesses on the car except the door harnesses and the small HVAC harness in the dash. You can cut the harness where it goes up into the headliner on both sides of the car. (updated 11-5-26).
  • electrical modules
    • There are many modules throughout the interior of the car that are required to start the car. Keep every module you find.
  • accelerator pedal
  • fuel pump
    • Can be removed from inside of the car after removing the rear seat.
  • fuel pump control module
    • This is mounted to the frame of the car above the fuel tank. You can get to it from the same spot you remove the fuel pump.
  • gear selector/shifter
  • ignition switch
    • Required if you are using the standard key setup to start the Goblin.
  • gauge cluster
  • push button starter
    • We aren't sure how easy it will be to reuse the starter button but save it if your donor has it.
  • brake master cylinder (added 10-21-2025)
  • brake fluid reservoir (added 10-21-2025)
Parts You WILL NOT Need
Powertrain Parts to Toss/Sell
  • driver side axle
  • passenger side axle
  • downpipe
  • passenger side engine mount
  • driver side transmission mount
  • radiator
  • intercooler
Front Suspension, Brakes, and Steering Parts to Toss/Sell
  • front control arms
  • front struts and springs
  • front knuckles
  • front bearing hubs
  • inner tie rods
  • outer tie rods
  • wheels (the Goblin kit comes with 5x114.3 bearing hubs that won't work with the VW 5x112 wheels)
  • brake calipers
  • rotors
Rear Suspension Parts to Toss/Sell
  • You will not need any of the rear suspension or brake pieces.
Miscellaneous Parts to Toss/Sell
  • brake pedal
  • clutch pedal
  • fuel tank (remove and keep fuel pump)
  • fuel filler neck
  • parking brake handle assembly
