Why are the SS Goblin V1 kits more expensive?
The SS versions of the Goblin V1 kit cost more because the supercharged (SS/SC) and turbocharged (SS/TC) versions require additional components that are not needed in base-model builds. You'll reus the factory supercharger or turbocharger from your donor car, but DF Kit Car must supply supporting hardware.
SS/SC (Supercharged) Goblin Kit
The SS/SC Goblin V1 kit does not include a supercharger but it does include additional parts to support the supercharger system.
To support the supercharged system, the kit includes additional components not found in the base Goblin kit:
  • SC MAF tube
  • Intercooler to heat exchanger plumbing
  • Heat exchanger with fan
  • SS shifter hardware
  • Shifter cables
  • Rear brake calipers
  • Rear brake rotors
These parts are required to adapt the supercharged Cobalt hardware to work properly in the Goblin.
SS/TC (Turbocharged) Goblin Kit
The SS/TC Goblin V1 kit does not include a turbocharger but it does include additional parts to support the turbocharger system.
The SS/TC kit includes even more components to support the turbocharged system:
  • Turbo MAF tube
  • Turbo intake tube
  • CNC machined turbo outlet adapter
  • Intercooler tube
  • Turbo MAP tube
  • Silicone elbows and adapters
  • T-bolt clamps
  • Water-to-air intercooler
  • Intercooler water pump
  • Shifter cables
  • SS/TC-specific fuel tank
  • Rear brake calipers with CNC machined brackets
  • Rear brake rotors machined to fit SS/TC hubs
