Wires to Send to DFKC for Harness Rework
Last updated: Nov 18, 2025 by Adam Doyle
DF Kit Car can rework your wiring harness for you. If you selected the harness rework option, or if you would like to add it, you will need to send in specific donor harnesses. If you did not choose this option when ordering your kit, please contact [email protected] before shipping any parts.
Please include a note in the box with your full name and, if available, your chassis number. This helps us match your harnesses to your build.
Shipping Address
Lonny Doyle
6651 Luber Rd.
Mountain View, AR 72560
Do not send the following items:
- Engine harness
- Fuse box or fuse box housing
- Body control module
- Ignition switch, gauges, or any other electrical components
Send the following harnesses:
Main Harness
Dash Harness
Remove from the dash by following this video: Disassembling the Dash
Headlight Harness
Fuel Pump Harness
Note: the SS/TC fuel pump harness will look slightly different.
Power Steering Harness
Large Positive Cable
