http://dfkitcar.com/forum/index.php?threads/richn-city-goblin-2007-lt-donor.94/page-2#post-2314Anyone running 5 lug hubs? I could only find ABS 5 lug hubs and the front wont fit into the uprights, the wheel sensor housing hits the steering beam on the upright. I popped off the bearing cap with sensor plug from the hub, now it fits but i need a new shorter hub cap... not sure where to get one.
Anyone run into this?
Make sure you're not making the same mistake I did... I couldn't tell that the jam nut was separate from the tie rod end - just thought that was the hex on the part and that someone had failed to reinstall the jam nut at some point. I kept trying to turn it to remove the rod end, but was actually tightening the jam nut against it.Thanks! BTW, i tried turning the adjustments on the arms but they are STUCK solid and dont want to move.
This is the only picture I have of the rear of the car that kind of shows them.Got them off. Installing the rear toe link now. Am i missing something? The taper on the rear uprights for the tie rod ends is tapered the wrong way so i cant get the tie rods in.... unless we are installing the rear tie rods upside down?
